stderr console
- nicotiere
01 Apr 2016 07:24 - 02 Apr 2016 12:00 #72510
by nicotiere
stderr console was created by nicotiere
une question toute bête, comment est ce que l'on ouvre cette console après avoir lancé linuxcnc sous Debian.
Merci
Edit: Translation
Merci
Edit: Translation
Ask any beast , how is it that this console is opened after launching linuxcnc Debian .
Last edit: 02 Apr 2016 12:00 by BigJohnT.
- nicotiere
02 Apr 2016 04:26 - 02 Apr 2016 12:01 #72554
by nicotiere
Replied by nicotiere on topic stderr console
bon pas de réponse, effectivement un peu trivial, suffisait de démarrer linuxcnc depuis un terminal. e que j'avais fait mais mes ptint (gcode) étaient mal codés)
Edit: translation
Edit: translation
good no answer, actually a bit trivial, was enough to start linuxcnc from a terminal. e I had done but my ptint ( gcode ) were poorly coded )
Last edit: 02 Apr 2016 12:01 by BigJohnT.
- BigJohnT
- Thank you received: 994
02 Apr 2016 12:03 #72563
by BigJohnT
Replied by BigJohnT on topic stderr console
As you may have noticed there is an international section and most posts are in English.
Comme vous avez pu le constater il y a une section internationale et la plupart des postes sont en anglais .
JT
JT
Time to create page: 0.164 seconds
