intermittant problem
- bill516
10 years 6 months ago #72700
by bill516
intermittant problem was created by bill516
Sometimes when I start to execute a program the spindle will start up and then the axis's jump then spindle slows down and keeps jumping and slowing down this till I stop the program. If I start the spindle manually before the program runs the stop start jumping does not happen.
Symptoms do not appear when I first switch on the machine and I can run a program a few times before the problem appears but once it happens I have to manually start the spindle.
I did think it might be a heat issue but none of the drivers seem to be too hot so I'm thinking it might be an amps issue.
Any ideas ?
Bill
Any ideas ?
Bill
10 years 6 months ago #72714
Replied by andypugh on topic intermittant problem
Sounds like a power-supply problem?
- bill516
10 years 6 months ago #72771
by bill516
Replied by bill516 on topic intermittant problem
Thanks Andy I'll try to check it out.
Bill
Bill
Time to create page: 1.279 seconds
