A few questios about Hal pins
05 Apr 2016 18:38 #72792 by kt600v
A few questios about Hal pins was created by kt600v
Hello everyone , i've been reading the basic hal reference , I would like you to help me to understand it better.
As far as i know the parallel port inputs are hal output pins and the port outputs are hal input pins.
When reading the manual i got confused with the following example :
# signal source destination destination
net xStep stepgen.0.out => parport.0.pin-02-out parport.0.pin-08-out
in my opinion the source (stepgen.0.out) connects to parallel port pin 02 and 08 (to move a stepper motor) and it should be like this:
net xStep stepgen.0.out => parport.0.pin-02-in parport.0.pin-08-in
I don“t know why destination pins are parport.0.pin-0X-out in the example.
Many thanks in advance for your reply
05 Apr 2016 19:26 #72796 by PCW
Replied by PCW on topic A few questios about Hal pins
The pin names reflect the ultimate destination (a parallel port output pin in this case)
but the parallel port output pin is an "IN" pin from the hal side
xStep stepgen.0.out --> parport.0.pin-02-out parport.0.pin-08-out --> physical pin
Note that parport.0.pin-02-out parport.0.pin-08-out is a input on the hal side but an output on the
physical side
The following user(s) said Thank You: kt600v
05 Apr 2016 20:20 #72808 by kt600v
Replied by kt600v on topic A few questios about Hal pins
sorry for the dummy question but, what do you mean with "an input on the hal side"
05 Apr 2016 20:50 #72811 by PCW
For example: parport.0.pin-02-out parport.0.pin-08-out
Is a hal input pin (that is, a pin that accepts a signal rather that provides a signal )
the physical step pin is of course an output
The following user(s) said Thank You: Clive S, kt600v
05 Apr 2016 22:45 #72817 by Clive S
Replied by Clive S on topic A few questios about Hal pins
It is nice to see this sort of thing discussed with good explanations of how the hal file is constructed and the work flow through it.
I have read and reread through most of the manuals and still find it very confusing but I am getting there slowly.
Thank you
Time to create page: 0.416 seconds
