line jumping on execut gcode?
- herbk
06 Apr 2016 06:59 #72826
by herbk
line jumping on execut gcode? was created by herbk
Hi Guys,
i have a generell question how the gcode prozessing works:
if i start running i gcode on linuxcnc, works it line after line? or is it or is it normal that there are some jumps (e.g. from line 72 to line 78 and then back to line 73)?
06 Apr 2016 09:43 #72833
Replied by andypugh on topic line jumping on execut gcode?
That depends on the G-code. Some G-code can have loop and branch instructions.
- herbk
06 Apr 2016 18:13 - 06 Apr 2016 18:15 #72859
by herbk
Replied by herbk on topic line jumping on execut gcode?
also if the gcode only consists G1, G2 and G3 lines?
Last edit: 06 Apr 2016 18:15 by herbk.
06 Apr 2016 18:15 #72860
Probably G4 too. You will only see the highlight on lines that actually take some time.
- herbk
06 Apr 2016 18:20 #72863
by herbk
There are no G4 lines, I checked the code before i asked.
