Time out on toolchange
  • emcPT
  • emcPT's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Apr 2016 17:23 #72923 by emcPT
Time out on toolchange was created by emcPT
Hello,
In a tool change component when something goes wrong a time out is normally present on machines that indicates that the tool change went wrong.
How can a time out be accomplished inside a component ? For example if the tool change does not occur in 10 seconds it should enter in error.
Thank you
07 Apr 2016 22:10 - 07 Apr 2016 22:12 #72934 by BigJohnT
Replied by BigJohnT on topic Time out on toolchange
I do my tool change in Classicladder so timers are easy.
I think (guess) you could make a timer of some sort in a component maybe counting cycles or something. Oh take a look at the time component it tracks time.
Edit: and look at the timedelay component.
JT
Last edit: 07 Apr 2016 22:12 by BigJohnT.
The following user(s) said Thank You: emcPT
08 Apr 2016 12:09 - 08 Apr 2016 12:09 #72954 by andypugh
Replied by andypugh on topic Time out on toolchange
You mean inside a realtime HAL component?
Typically a HAL component is written as a state machine:
state = 0;
switch state{
case 0: // idle
   if (thing) {
      stuff;
     state = 1
case 1: // begin
   if (other thing){
      more_stuff
     state = 2
and so on.
To add a timeout:
state = 0;
switch state{
case 0: // idle
   if (thing) {
      stuff;
    timer = 0;
     state = 1
case 1: // begin
   timer += period; // period is in nS
   if (timer > 1000000) {
       state = 99;
      break
   if (other thing){
      more_stuff
     timer = 0
     state = 2
  case 99:  // Handle timeout heree
Last edit: 08 Apr 2016 12:09 by andypugh.
  • emcPT
  • Platinum Member
  • Platinum Member
08 Apr 2016 16:17 #72968 by emcPT
Replied by emcPT on topic Time out on toolchange
Yes, we implemented like a delay (that we were using in another machines) and quite similar to your implementation and it works fine.
About the classicladder I never tested as we are able to do almost anything with components.
Time to create page: 0.096 seconds
