MESA 5125 with Probotix Controller
07 Apr 2016 18:23 #72925 by Irritant
MESA 5125 with Probotix Controller was created by Irritant
I have just installed a MESA 5125 to solve latency problems. Except these errors it was configured okay for Probotix on the parallel port. With the new card nothing happens or works. Does anyone have this combo and can send me their config files to look at? I don't know what I am doing with this stuff and don't have weeks to learn.
Thanks!
07 Apr 2016 22:06 #72933 by BigJohnT
Replied by BigJohnT on topic MESA 5125 with Probotix Controller
Did you get the last hal file I sent you?
Did you try the Pncconf configuration you made?
And yes if someone has a configuration please post it.
JT
08 Apr 2016 11:58 #72951 by andypugh
Replied by andypugh on topic MESA 5125 with Probotix Controller
Do you know which firmware is on the 5i25? There is a specific one for the Probotix breakout card.
08 Apr 2016 12:00 #72952 by BigJohnT
Yes, I flashed it with the Probotix firmware.
JT
08 Apr 2016 12:54 #72957 by Irritant
Replied by Irritant on topic MESA 5125 with Probotix Controller
I tried the new hal file, does not run.
I do hear the controller come to life when I switch on and the steppers have power. When I was running without the 5125 the estop switch worked even if the controller was off, but not now, it gives no indication that it works. And so there are no misunderstandings I am using the Unity controller from Probotix. I emailed them and Len said that as long as the pin setup matches it should run okay.
08 Apr 2016 13:03 - 08 Apr 2016 13:43 #72958 by Irritant
Sorry just making the water muddy talking about two config files at the same time.
Last edit: 08 Apr 2016 13:43 by Irritant.
08 Apr 2016 13:05 #72959 by Irritant
Running the MessaProb config I mow get the message,
joint 0 following errors
08 Apr 2016 13:46 #72961 by Irritant
Also when the config runs it has an old name displayed, I guess this is something left over in the config file that JT moded.
08 Apr 2016 14:33 - 08 Apr 2016 14:41 #72962 by BigJohnT
So with the configuration I changed the drives are getting enabled now and powering up. What happened when you tried the Pncconf configuration you made? Zip up the configuration directory and post it so others can look at it. I didn't change the machine name.
Edit: I think I see where I forgot to convert something the step and direction to the stepgen! Note to self only try to do 3 things at once...
JT
Last edit: 08 Apr 2016 14:41 by BigJohnT.
08 Apr 2016 14:56 - 08 Apr 2016 15:30 #72964 by BigJohnT
Hmm, I'm missing something when I test the config on my plasma I don't see any stepgen counts change when I jog.
Edit: I seem to be missing a lot when I compare it to a pncconf configuration that works btw.
JT
Last edit: 08 Apr 2016 15:30 by BigJohnT.
Time to create page: 0.126 seconds
