How do I setup a 5 axis mill?
7 years 1 day ago #149286 by jackotool
Where is LinuxCNC 2.8? - On the main page I see only version 2.7
7 years 1 day ago #149291 by tommylight
linuxcnc.org/downloads/
Download the stretch version, install it to HDD, then go to :
buildbot.linuxcnc.org/
for info on how to upgrade to 2.8 or 2.9
7 years 1 day ago #149292 by andypugh
I would suggest running 2.7 to start with. 2.7 can do TCP too.
How do you intend to generate G-code? That will rather determine which way the machine should be configured.
6 years 11 months ago #149477 by jackotool
Thanks .. Another issue with Linux CNC - I use terminal ls /dev/parport* no such file or directory in linuxcnc - cannot see parallel port in LinuxCNC but can see it in Linux Mint for example - any simple solution to fix this?
Also this version of LinuxCNC prevents me from updating anything - it won't even allow me to select another server ...
Any help please ... This is very frustrating and very buggy ...
Thanks!
6 years 11 months ago #149562 by andypugh
jackotool wrote: Also this version of LinuxCNC prevents me from updating anything !
Which version are you using? (ie, which .iso did you download?)
www.linuxcnc.org/downloads/
If you are not using the 2.7 Debian 9 Stretch version them please try that.
6 years 11 months ago - 6 years 11 months ago #149578 by jackotool
Hi, Thanks for the reply ... It is my error - I had three cards that had parallel port connecter - one of them works, the other two do not - I did not test the card that really connects again is all OS versions. If anyone require more details about what does/doesn't work in my case ... let me know ..
Meanwhile, how many parallel ports are required for 5 axis - is one sufficient?
Also, has anyone tried connecting a PCIe parallel port card to a PCIe/PCI adapter - would there be any serious latency issues?
By the way I am using LinuxCNC Debian STRETCH - the Wheezy version has some issues like it would not connect to server and would not allow me to choose a server near me etc - also my network card was not recognized, but my USB to network cable adapter was. In LinuxCNC STRETCH I have not had any issues at all so far!
Thanks!
Last edit: 6 years 11 months ago by jackotool. Reason: Additional information
Time to create page: 0.272 seconds
