1 if you do not need anything else. It has 12 output pins, 2 for each drive as step/dir, one for enable to all drives and you have one spare for something else. Also it has 5 inputs for 5 limit/home switches.jackotool wrote: Meanwhile, how many parallel ports are required for 5 axis - is one sufficient?
If it works then there will be no significant hardware delay.Also, has anyone tried connecting a PCIe parallel port card to a PCIe/PCI adapter - would there be any serious latency issues?
