How do I setup a 5 axis mill?
08 Nov 2019 09:52 #149908 by jackotool
Replied by jackotool on topic How do I setup a 5 axis mill?
One more issue I'm not clear on is operating spindle inside LinuxCNC - I see some people using a RS 485 from VDF to USB and others via a breakout board ...
Please advise what works best and other recommendations ...
Thanks!
08 Nov 2019 11:50 #149910 by andypugh
Replied by andypugh on topic How do I setup a 5 axis mill?
RS485 via USB is not realtime. That is not usually a problem with a milling machine, but might not be ideal if running a lathe in CSS mode.
Conversely the RS485 link will give you a lot more feedback from the drive back to LinuxCNC. See the list of pin names here as an example:
linuxcnc.org/docs/2.8/html/man/man1/hy_vfd.1.html
The following user(s) said Thank You: jackotool
Time to create page: 0.780 seconds
