G Code Consult.
- Marfil
- Thank you received: 3
08 Apr 2016 20:04 #72975
by Marfil
G Code Consult. was created by Marfil
Hi, I've a question. Is posible in G code put a msg like "please insert the X value" ? ( currently the machine is paused.) Once I set the value, the machine goes on.
It is possible?
Thanks.
It is possible?
Thanks.
- eFalegname
- Thank you received: 30
10 Apr 2016 07:22 #73038
by eFalegname
Replied by eFalegname on topic G Code Consult.
Like this:
(MSG, Please insert the X value)
M0
M0
- Thank you received: 4652
11 Apr 2016 13:24 #73103
Popping up a message is very easy.
Actually getting a numerical value into G-code is a lot less easy. When G-code was developed there was no consideration given to user interactivity. Even the (MSG, .... ) format is just a special case of a g-code comment line. (described here: linuxcnc.org/docs/2.7/html/gcode/overview.html#gcode:comments )
One way to do what I think you want to do is here:
forum.linuxcnc.org/forum/38-general-linu...iable?start=10#57149
Replied by andypugh on topic G Code Consult.
Is posible in G code put a msg like "please insert the X value" ? .
The following user(s) said Thank You: Marfil
- Marfil
12 Apr 2016 01:56 #73137
by Marfil
Replied by Marfil on topic G Code Consult.
Thanks Andypugh for your support
As you told me, exactly that ! But is not too easy for me.
Regards
Regards
Time to create page: 0.075 seconds
