manual mill converted to cnc
10 years 6 months ago #73541
by thor44
Replied by thor44 on topic manual mill converted to cnc
I have a friend that has Mach I'll check it out when he finishes building his machine, it's only been six years now so I'm not sure if he will actually finish it or not.
I am using backlash comp, I need to figure out how much to compensate for.
What kind of machine are you running?
10 years 6 months ago - 10 years 6 months ago #73546
by Fastest1
Replied by Fastest1 on topic manual mill converted to cnc
Some projects take longer than others
I have quite a few machines in various states of disrepair. I will get 1 running only to see someone on a forum either do a better job or I will learn a better way and rip it apart again. It is a disease.
I have a Sherline 15" CNC lathe. It was a conversion from an educational model that has been modded.
An A2ZCNC Monster Mill that has also been used as a 3D printer after I built an extruder.
A Dyna DM2400 mill
A Dyna DM3000 lathe
A G0704. I better stop now before the wife sees this list or I realize I need to clean out the garage.
Regarding backlash. First make sure that backlash compensation is OFF..
Then command your machine to move a specific measurement in 1 direction (an inch for example) do this twice in the same direction (this takes the backlash out on the first command in case the last move had been the other direction), verify it the last time with a DTI or similar (this step is to verify the machine went the proper distance) Zero your indicator. Then command that same axis the opposite direction, the same distance as before. There will be a difference, this difference is backlash. Repeat it a few times just to be sure.
If the amount varies each and every repeat, you will need to adjust the gibs properly.
I am trying to learn LCNC just because of frustration with small issues occasionally in Mach or Windows, not really sure of the culprits. However the programming is not my forte, at all. I see that what I want can be done but it is almost impossible to see how. I will have to go hang around a local Makerspace or similar to get some hands on. There are so many variables it is hard to grasp. On the other hand, both OS's (Linux/Windows) use the same hardware which is why I was suspicious of the parallel port.
A Dyna DM2400 mill
A Dyna DM3000 lathe
Last edit: 10 years 6 months ago by Fastest1.
10 years 6 months ago - 10 years 6 months ago #73548
by Fastest1
Btw some of that frustration is also likely due to the fact that CNC doesnt require the latest greatest PC's. In fact they can be a hindrance. So most of the PC's allocated to running machines are old POS computers that were dug out of attics, handed down etc. They are old in the first place.
I built a mini itx this weekend from an Intel Atom D525M (has great driver tests in Mach) for my G0704. We will see.
Didnt mean to hijack your thread.
10 years 6 months ago #74074
by thor44
I found the problem, I didn't notice at first that the acme screw and the gibbs are not aligned causing a bind so it should work once I get the time to fix it.
Time to create page: 0.116 seconds
