manual mill converted to cnc
- thor44
- Topic Author
10 years 6 months ago #73047
by thor44
manual mill converted to cnc was created by thor44
OK guys I need some advice.
I converted a manual mill to cnc and I was running a program the other day and in the middle of program the x axis stalled fortunately it was in between holes so no damage was done, so I reset the part started again and everything went just fine. I started part 2 and the same thing I had run the program twice.
The machine is a Jet jmd-15. I'm using 570 once inch stepper motors with 3 to 1 belt drive the stepper drivers are set to micro step level one (200 steps per rev) a total of 6000 steps per inch, 3 amps motor current , half current at idle.
What could cause it to stall in the middle of the program one time but not the another?
Orson
Orson
- BigJohnT
- Thank you received: 994
10 years 6 months ago #73050
by BigJohnT
Replied by BigJohnT on topic manual mill converted to cnc
Something mechanical? When you say the program stalled did LinuxCNC stop working or did an axis stall out?
JT
JT
- thor44
- Topic Author
10 years 6 months ago #73051
by thor44
Replied by thor44 on topic manual mill converted to cnc
The program continued to run and the axis stopped moving. I immediately stopped the machine and was able to jog back to point were the problem started and jog back and forth with no problems and then jog back to 0 and then restart the program.
Orson
Orson
- BigJohnT
10 years 6 months ago #73053
by BigJohnT
That would be a mechanical or electrical issue most likely. With a stepper drive LinuxCNC has no idea if the axis is in position or not so the program just keeps running. If the stepper stalled then usually it will not restart until you stop the step pulses.
JT
JT
- thor44
- Topic Author
10 years 6 months ago #73054
by thor44
I'll check the mechanical parts. Any idea what electrical problems would cause this?
- BigJohnT
10 years 6 months ago #73055
by BigJohnT
Loose connections, stepper drive problems...
JT
JT
The following user(s) said Thank You: thor44
- thor44
- Topic Author
10 years 6 months ago #73448
by thor44
I had the acme screw nuts to tight and causing a ton of resistance so loosened them up and it looks like it will run pretty good now, I guess I'm going to have to live with some back lash.
Thanks for the help.
- Fastest1
10 years 6 months ago #73493
by Fastest1
Replied by Fastest1 on topic manual mill converted to cnc
Are you running a Mesa card or the Parallel Port?
- thor44
- Topic Author
10 years 6 months ago #73494
by thor44
I'm using a parallel port for now but I would like to use a mesa card when I can afford it.
- Fastest1
10 years 6 months ago #73509
by Fastest1
Having been a Mach 3 user for years via PP (I have used USB and Ethernet SmoothSteppers too) . I am now trying to understand LinuxCnc and its pros and cons.
What I have noticed is that LCNC and Mach are sensitive to the computer itself. Mach calls it a driver test. LCNC a maximum jitter. They might be one and the same I dont know. I do know I have run Mach on many different PC's and experienced different results. Some set ups were capable of high rapids, some stalled at random times. I never could trace the issue but the PC's had very similar specs generally.
That was why I asked about the parallel port. After looking thru the forums, it appears LCNC might not be trouble free either.
