Embroidery machine
- mozmck
- Thank you received: 59
14 Apr 2016 15:11 #73308
by mozmck
Replied by mozmck on topic Embroidery machine
Here is a quilting machine running linuxcnc. It was done by micges here on the forum.
The following user(s) said Thank You: allenwg2005, roughtyper
- fabatecperu
12 Jan 2018 16:52 - 12 Jan 2018 16:56 #104344
by fabatecperu
Replied by fabatecperu on topic Embroidery machine
friend.
only the linuxcnc is used, what modifications have to be done so that the table only moves when the needle is up, or nothing is needed. I will thank you very much. Thanks a lot to everyone.
I did not find any information about micges
Last edit: 12 Jan 2018 16:56 by fabatecperu.
- fabatecperu
12 Jan 2018 16:57 #104345
by fabatecperu
Is there any manual to program the linuxcnc and do some modifications or customizations? I want to control sewing machine.
- BigJohnT
- Thank you received: 994
12 Jan 2018 17:07 #104346
by BigJohnT
Replied by BigJohnT on topic Embroidery machine
linuxcnc.org/docs/2.7/html/
I imagine that the G code for moving is done after the needle is up ie. a bunch of short moves...
JT
JT
- Thank you received: 4652
12 Jan 2018 17:08 - 12 Jan 2018 17:09 #104347
Replied by andypugh on topic Embroidery machine
I don't see any indication that that machine only moves when the needle is up.
I imagine that you could potentially do it by using the adaptive feed HAL pin as a function of needle position.
Last edit: 12 Jan 2018 17:09 by andypugh. Reason: removed duplicate link.
- bevins
- Thank you received: 338
08 May 2021 09:17 #208292
by bevins
Replied by bevins on topic Embroidery machine
Are those head available? That is cool....
- Thank you received: 7468
04 Aug 2021 18:44 #216931
Replied by tommylight on topic Embroidery machine
Spam or not ?
- phillc54
- Thank you received: 2100
04 Aug 2021 23:18 #216945
by phillc54
Replied by phillc54 on topic Embroidery machine
The gambling ad makes me think so.
05 Aug 2021 10:03 #216957
Thank you Phill, my main PC is busy last few days so on the phone and since i have everything locked down i can not see adds or scripts or anything like that.
And i refrain from loging in on other PC's, always.
Yeah, paranoia !
Yeah, paranoia !
- SallyR12
- Visitor
06 Oct 2021 05:17 - 02 Jan 2022 13:36 #222330
by SallyR12
Replied by SallyR12 on topic Embroidery machine
I don't think it would be very difficult, especially if you were just converting an existing machine. I have followed a detailed {link unrelated to LinuxCNC removed by moderator}
Last edit: 02 Jan 2022 13:36 by andypugh.
Time to create page: 0.107 seconds
