no_force_homing on LinuxCNC 2.6
09 May 2016 19:03 #74424 by RomeReactor
no_force_homing on LinuxCNC 2.6 was created by RomeReactor
Hello.
We're trying to run LinuxCNC 2.6 with "NO_FORCE_HOMING = 1", but it doesn't work. We searched and haven't come up with a definite answer as to why. The option works in 2.7, but we can't use it because LCEC doesn't load there. Using Ubuntu 12.10, LinuxCNC 2.7 from the repositories, and 2.6 from here .
Thanks in advance
10 May 2016 16:14 #74453 by andypugh
Replied by andypugh on topic no_force_homing on LinuxCNC 2.6
NO_FORCE_HOMING did work in 2.6. Is it possible that you put it in the [AXIS] section rather than the [TRAJ] section in error?
The following user(s) said Thank You: RomeReactor
10 May 2016 20:58 #74475 by RomeReactor
Replied by RomeReactor on topic no_force_homing on LinuxCNC 2.6
It was in the [TRAJ] section, but It refused to work by itself. We managed to get it working by setting "self.all_homed = True" in gscreen.
Thanks for the reply :)
Time to create page: 0.149 seconds
