Tool in spindle memory
7 years 6 months ago - 7 years 6 months ago #131173 by nkp
Last edit: 7 years 6 months ago by nkp.
7 years 6 months ago #131174 by Todd Zuercher
It is normally saved in your machine's config dir
7 years 6 months ago #131252 by nkp
Replied by nkp on topic Tool in spindle memory
diff -ruN a/interp_array.cc b/interp_array.cc
--- a/interp_array.cc 2019-04-19 21:06:06.417653618 +0300
+++ b/interp_array.cc 2019-04-19 21:05:30.009473042 +0300
@@ -224,7 +224,7 @@
5381, 5382, 5383, /* coordinate system 9 */
5384, 5385, 5386, /* A, B, & C */
5387, 5388, 5389, /* U, V, & W */
- 5390,
+ 5390,5400,
RS274NGC_MAX_PARAMETERS
7 years 6 months ago #131255 by andypugh
Replied by andypugh on topic Tool in spindle memory
Adding it manually to the .var file seems like a reasonable way to enable the behaviour.
What is then needed is for iocontrol (or similar) to load the tool if it finds it non-zero in the .var file.
I think that Chris was looking at this?
The following user(s) said Thank You: Shu
7 years 6 months ago #131257 by newbynobi
Replied by newbynobi on topic Tool in spindle memory
Why don't you use gmoccapy?
Just go to the settings page and enable "reload tool on start up"
After that gmoccapy will set the last tool in spindle with an MDI command after you homed the machine.
Norbert
7 years 6 months ago #131259 by andypugh
newbynobi wrote: Why don't you use gmoccapy?
Because this is a feature which shouldn't depend on the GUI.
(Gmoccapy attempts to fix too many shortcomings of LinuxCNC in the GUI when really they should be fixed for all GUIs in the common code)
The following user(s) said Thank You: JetForMe
Time to create page: 0.072 seconds
