- Thank you received: 2181
andypugh wrote: Adding it manually to the .var file seems like a reasonable way to enable the behaviour.
What is then needed is for iocontrol (or similar) to load the tool if it finds it non-zero in the .var file.
I think that Chris was looking at this?
cmorley wrote: I'm not sue there are many active devs left in linuxcnc though...
