problem setting up external e stop
  • markd
  • markd's Avatar Topic Author
  • Visitor
  • Visitor
14 May 2016 15:26 #74650 by markd
problem setting up external e stop was created by markd
I have been able to get the estop chain working except that I need output07 to drive a relay. There is no change in the state of output07 when the software estop is toggled. I have attached my hal file. Can anyone point me in the right direction to fix this problem.
File Name: MiniLathe.hal
File Size:0 KB
  • markd
  • Visitor
  • Visitor
14 May 2016 15:32 #74651 by markd
Replied by markd on topic problem setting up external e stop
File Name: MiniLathe-2.hal
File Size:11 KB
Here is the file
15 May 2016 10:47 - 15 May 2016 10:51 #74676 by cncbasher
Replied by cncbasher on topic problem setting up external e stop
you appear to have the estop commented out ?
# net estop-out <= iocontrol.0.user-enable-out
# net estop-ext => iocontrol.0.emc-enable-in
you may when using mesa cards need to invert the output
what relay / module are you using on the output ?
Last edit: 15 May 2016 10:51 by cncbasher.
  • markd
  • Visitor
  • Visitor
15 May 2016 14:09 #74680 by markd
Thank you for the reply'. I need to activate a solid state relay which controls power to the drives and VFD.
16 May 2016 09:26 #74732 by cncbasher
you should be fine in that case , but watch that you may need to invert the output pin as i previously said
  • markd
  • Visitor
  • Visitor
16 May 2016 13:03 #74741 by markd
Thanks the estop chain is now working as required. I will now start the hardware check out. Although I have been using LinuxCNC for a while now this is the first time hand coding my hal files. I expect to run into other unforeseen problems.
Time to create page: 1.334 seconds
