How do you set zero coordinates?
16 May 2016 06:29 #74724 by mjohnsonsa
How do you set zero coordinates? was created by mjohnsonsa
Can you guys tell me where the 'Zero Coordinates' is in LinuxCNC? In Mach my workflow was like this:
- Move bit to lower left corner of work piece where I want cut to start and lower bit so it touches the top corner of the material
- Hit 'Zero Coordinates' button
- Raise the Z-Axis and turn on my spindle
- Hit 'Go To Zero' button
- Start file
I do not see in LinuxCNC where you can duplicate this workflow, am I missing something? Surely there is a way to place the bit where you want the print to start and then make that your 0 point right?
16 May 2016 06:32 #74725 by emcPT
Replied by emcPT on topic How do you set zero coordinates?
Did you tested touch off?
16 May 2016 11:19 - 16 May 2016 11:23 #74734 by Rick G
Last edit: 16 May 2016 11:23 by Rick G.
16 May 2016 16:10 - 16 May 2016 16:12 #74749 by mjohnsonsa
Replied by mjohnsonsa on topic How do you set zero coordinates?
So what am I doing wrong here?
1. I home the machine to machine 0,0,0
2. I jog the machine to where I want to start cutting on my workpiece
3. I hit the 'Touch Off' button while selecing the Z-Axis (bit is sitting on top corner of workpiece), leave the form value at 0.0 and hit okay.
4. I repeat #3 for X and Y (bit still at top corner of workpiece where I want it to start)
5. I hit play, it runs the program and then errors with this line: "N365 G53 Z0." The error says:
"Linear Move on Line 75 would exceed joint 2's positive limit"
In my .ini file Z-Axis which is joint 2 I believe is set with MIN_LIMIT = -6.0 and MAX_LIMIT = 0
Last edit: 16 May 2016 16:12 by mjohnsonsa.
16 May 2016 16:35 #74752 by Todd Zuercher
Replied by Todd Zuercher on topic How do you set zero coordinates?
Because your home position (machine Z0) is = to your Z max soft limit, it is setting the alarm. Try to adjust your soft limits so they home position is within them. Maybe make your Z MAX_LIMIT = 0.1. If you don't have enough free travel to do that, you could adjust your homing position to give you the needed space. Typically I home to a limit switch, then set the home and home offests so that the home position (X0,Y0,Z0) is a half inch or more away from the home/limit switches. This gives you enough wiggle room to set the soft limits so they don't get in the way.
16 May 2016 16:54 #74754 by mjohnsonsa
Todd, look at this post to see the problem I was having with my soft limits: forum.linuxcnc.org/forum/38-general-linu...t-limits-with-homing
So your HOME = 0, your HOME_OFFSET = to half inch inside the MAX_LIMIT? If so, then you can jog right into your limit switch and forego the benefit of the soft limit where you do not have to click override in order to get off the switch
If I am misunderstanding, can you tell me what your HOME, HOME_OFFSET, and MAX_LIMIT values are and maybe that will help?
Thanks.
16 May 2016 17:39 #74758 by Todd Zuercher
In my config, I have the Z HOME=0, HOME_OFFSET=0.5 and the MAX_LIMIT=0.3. I can then jog the machine up, 0.3 before it hits the soft limit, the hard limit is an additional .02 further up.
16 May 2016 17:45 - 16 May 2016 17:45 #74759 by Todd Zuercher
Do you have an entry HOME_IGNORE_LIMITS for each axis in your ini file? Is it set to YES or NO? If you're homing to a limit switch this needs to be set to YES for each axis that uses a combined home/limit switch.
Last edit: 16 May 2016 17:45 by Todd Zuercher.
16 May 2016 18:05 #74762 by mjohnsonsa
Yes, it is is set to HOME_IGNORE_LIMITS = YES but what is happening is since the MAX_LIMIT is reached before the hard limit switch it throws a soft limit error and will not move to homing the next axis. Do you not have that problem with your soft limit being before your limit switch when you hit "Home All"?
16 May 2016 18:16 #74764 by Todd Zuercher
I do not have this problem. Before homing there should be no soft limits, since Linuxcnc does not know where it is to even begin to calculate them. Maybe you should post copies of your ini and hal files so we can see what your working with.
Time to create page: 0.111 seconds
