How do you set zero coordinates?
16 May 2016 18:35 #74767 by mjohnsonsa
Replied by mjohnsonsa on topic How do you set zero coordinates?
I think I figured out my problem. I was using my finger to simulate the gantry hitting the switch to prevent crushing my switch during testing (I have done it before when my velocities were reversed) every time I did this I was getting the soft limit error, I think what was happening is I was holding down the first hit of the switch too long while it backed up to home, then I would let go as it homes in and somehow my timing was letting things go past where they should have stopped I think. Once I let the machine do it the error did not occur.
Now back to see if I get the problem trying to run my G-Code. Is the process I listed up top correct procedure? it seems like there should just be a button that zeros all axis rather than hitting each one select radio, hitting the touch off button, and then repeating....
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
16 May 2016 19:08 - 17 May 2016 12:35 #74770 by Todd Zuercher
Replied by Todd Zuercher on topic How do you set zero coordinates?
I think what you described earlier sounded right.
I don't think there is a stock one button click way to zero all the axis coordinates, but it isn't difficult to make one, and it can be done with an MDI command.
G10 L2 P1 X0 Y0 Z0
Last edit: 17 May 2016 12:35 by Todd Zuercher.
16 May 2016 20:46 #74776 by joekline9
Replied by joekline9 on topic How do you set zero coordinates?
When you touch off Z use tool n touch off and it will create a tool offset for Tool n.
put 'M6 Tn G43' in your g code before any cutting lines. (n is tool number)
Then G53 G0 Z0 will retract Z to home position.
G0 Z0 will move Z to top of part.
The following user(s) said Thank You: mjohnsonsa
17 May 2016 08:22 #74788 by Rick G
Time to create page: 0.198 seconds
