Can Ubuntu run MESA card driver?
- mjohnsonsa
24 May 2016 01:05 - 24 May 2016 01:07 #75014
by mjohnsonsa
Can Ubuntu run MESA card driver? was created by mjohnsonsa
I installed Ubuntu Precise 12.04 with kernel 3.4-9-rtai-686-pae
I installed linuxcnc 2.7 and ran pncconf and when I start linuxcnc I get "Can't find module 'hm2_eth' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc"
I googled the error and found one other person who had the same problem. Apparently the hm2_eth can only run on a kernel compiled with 'uspace' and in the man page for hm2_eth it sounds like uspace is not available on Ubuntu. Is this information still current and valid? Do I need to ditch my Ubuntu install and run Debian Wheezy instead in order to use the Mesa 7I76e card I just purchased?
If not, what do I need to do to get it working? Thanks.
Matt
Matt
Last edit: 24 May 2016 01:07 by mjohnsonsa.
- Thank you received: 1476
24 May 2016 02:29 #75017
Replied by Todd Zuercher on topic Can Ubuntu run MESA card driver?
Yes, to use one of Mesa's Ethernet cards you need to install the Preempt RT kernal instead of the RTAI one. (I think this can be done through synaptic)
Once you get the right kernel installed then you need to install the right version of Linuxcnc (the uspace one.)
You might need to dig arround to find the exact instructions and what the right repository settings would be for your os.
- Thank you received: 5329
24 May 2016 02:53 - 24 May 2016 02:56 #75019
Replied by PCW on topic Can Ubuntu run MESA card driver?
Sure, I'm running LinuxCNC Ethernet cards on Wheezy, Ubuntu (14.04) and Linux Mint (17.3)
"uspace:" is a linuxcnc option, for Mesa Ethernet cards, you need to use the uspace version of linuxcnc
and a Preempt-RT kernel
You can build a preempt-RT kernel for most systems (including ubuntu) fairly easily:
The following script will build the latest of the 4.1 series of real time kernels:
cd ~
sudo apt-get update
sudo apt-get install build-essential bin86 kernel-package libqt4-dev libncurses5-dev pkg-config
mkdir rtlinux
cd rtlinux
wget ftp://ftp.kernel.org/pub/linux/kernel/v4.x/linux-4.1.20.tar.xz
wget www.kernel.org/pub/linux/kernel/projects...4.1.20-rt23.patch.gz
tar -xpf linux-4.1.20.tar.xz
gunzip patch-4.1.20-rt23.patch.gz
cp patch-4.1.20-rt23.patch linux-4.1.20
cd linux-4.1.20
cat patch-4.1.20-rt23.patch | patch -p1
make xconfig
make -j4
sudo make modules_install
sudo make install
When this brings up xconfig you must at the minimum select the 32 or 64 bit option and
(under processor type and features)
HPET timer support and Fully Preemptable Kernel (under Preemption model)
This will require a fair amount of disk and time to compile
cd ~
sudo apt-get update
mkdir rtlinux
cd rtlinux
cd linux-4.1.20
make xconfig
make -j4
sudo make install
Last edit: 24 May 2016 02:56 by PCW.
- mjohnsonsa
24 May 2016 03:35 #75020
by mjohnsonsa
Replied by mjohnsonsa on topic Can Ubuntu run MESA card driver?
Does the version of linuxcnc that supports uspace also support the gantry component? I don't remember if I am running a beta or not to get the gantry component support...
24 May 2016 12:22 #75039
yes
25 May 2016 10:54 #75066
Replied by andypugh on topic Can Ubuntu run MESA card driver?
Possibly worth noting that Joints_Axes14 currently does gantry-homing a bit more smoothly than the Gantry component.
See the new negative-number homing sequence option here:
buildbot.linuxcnc.org/doc/scratch/v2.8.0....html#_home_sequence
Of course that definitely _is_ a development version.
