JA14 not homing...
- Thank you received: 4648
27 May 2016 09:57 #75144
Replied by andypugh on topic JA14 not homing...
If you want the option to jog both sides of the gantry separately, then you can useNow at start-up the system will be in "Joint Mode" where you will have control of the 4 numerical joints rather than the cartesian coordinates.
If you are configured this way and you are using the Axis GUI you can add to the INI so that the system automatically switches to "Teleop" (XYZ) mode after homing.
linuxcnc.org/docs/ja/html/getting-starte...uxcnc.html#_axis_gui
So, with such a setup you would have a 0,1,2,3 machine at power-on, you could jog each motor individually to manually square the gantry, then hit "home-all" and the machine would run the homing sequence and then turn into an XYZ machine.
Without auto-telop you can use the $ key to toggle between the modes.
loadrt trivkins coordinates=XYYZ kinstype=BOTHIf you are configured this way and you are using the Axis GUI you can add to the INI so that the system automatically switches to "Teleop" (XYZ) mode after homing.
- dgarrett
- Thank you received: 297
27 May 2016 12:33 #75153
by dgarrett
Replied by dgarrett on topic JA14 not homing...
The option for switching to teleop was removed prior to the
rebase for joints_axes14:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...4f3b4d534bcbf5350e7a
It is no longer optional (you can switch back to joint mode
after homing using the '$' key in the axis gui or using the
halui pin halui.mode.joint)
- Thank you received: 1471
27 May 2016 12:45 - 27 May 2016 13:12 #75154
Replied by Todd Zuercher on topic JA14 not homing...
I get the impression that the original poster is a new Linuxcnc user and is realy struggling with the basics of editing config files manually. Add on top of that the fact that there aren't examples posted of what he's trying to do, and the fact that Pncconf isn't ready for JA.
Upton closer examination of his config files posted earlier, they are going to need a lot of messing about with to get where he wants to go.
For your 4th joint (Y2) to be able to move and home independently from the master, it will need to have it's own PID, stepgen, and home switches.
Here is some rough adjustments to your previous config files that might maybe work, but should at least get you started and pointed in the right direction.
Is this the input for the limit switch of your Y2?My second Y axis stepper should be on hm2_7i76e.0.7i76.0.0.input-03...
Last edit: 27 May 2016 13:12 by Todd Zuercher.
The following user(s) said Thank You: mjohnsonsa
- mjohnsonsa
27 May 2016 13:30 - 27 May 2016 13:37 #75155
by mjohnsonsa
Replied by mjohnsonsa on topic JA14 not homing...
Yes this is correct. I am almost there all that is left is squaring automatically during homing. I have no desire to jog Y and Y2 independently, I would rack the gantry! I want them to always run in lock step and only work independently with their own limit switches when homing. I have a working config on standard LCNC using the Gantry component and am trying to replicate that functionality in JA14 without using the gantry component. And yes, my Y2 stepper is input-03.
Thanks for the revised configs, I will give them a try
Last edit: 27 May 2016 13:37 by mjohnsonsa.
- BigJohnT
- Thank you received: 994
27 May 2016 13:48 #75158
by BigJohnT
Replied by BigJohnT on topic JA14 not homing...
If the home switches are not perfect adjust the home offset to end up with a square gantry. The squaring is done during the move to home not while homing.
JT
JT
27 May 2016 14:19 #75162
But to be able to square themselves they must be able to move independently (for that squaring move at least)
- mjohnsonsa
27 May 2016 16:45 #75166
by mjohnsonsa
Yes, I understand that. During homing they would be independent so they each hit their respective limit/homing switch rather than stop on the first side that hits.
27 May 2016 19:21 - 27 May 2016 20:15 #75170
I was not sure you did. In the configuration files you posted earlier, your Y-1 and Y-2 are connected to the same command source joint.1, so there is no way for the 2 joints to home or do anything independent of each other. Things are further muddied by the fact that you had the Y-1 stepgen configured in velocity mode with a PID, and the Y-2 configured in position mode. (setting up the 2 sides differently like that seems like asking for trouble in a whole other context).
In the config I posted I set up (or tried to set up) your Y-1 and Y-2 configured as joint.1 and joint.3. in order to take advantage of JA14's new Trivkins kinematics that takes care of the slaving internally, allowing Linuxcnc to home both sides and square the gantry.
Last edit: 27 May 2016 20:15 by Todd Zuercher.
27 May 2016 19:43 #75171
Just a point of info, not really important, in JA there is no Y master and Y slave. Just two equal and identical joints, controlled by the same Axis word.
- mjohnsonsa
27 May 2016 20:16 #75172
by mjohnsonsa
Todd, your file worked perfectly and does exactly what I needed it to do. Thanks.
Time to create page: 0.108 seconds
