Steeper motor control
10 years 4 months ago #75400 by avaneeshritwik
can I control six stepper motors ( 3 for xyz and 3 for orientation) using the linuxcnc platform?
10 years 4 months ago #75401 by andypugh
Replied by andypugh on topic Steeper motor control
Yes. You can control up to 9 motors directly from G-code, and many more than 9 if you don't need coordinated motion.
Software stepping is limited to 16 motors (unless you recompile LinuxCNC). Mesa cards do not have any obvious limit on the number of stepgens supported, and I can't immediately see how many stepgen channels are supported by the Pico driver, but it seems to be 4 per parallel port.
10 years 4 months ago #75402 by cncbasher
Replied by cncbasher on topic Steeper motor control
yes linuxcnc can control up to 9 ( xyzabcuvw) other stepgens can be available
all depends on what your using to interface etc
what do you mean by orientation ? if you mean a,b,c axis then they are incorporated
but overall linuxcnc is fully configurable , to do many things
Time to create page: 0.137 seconds
