Need help with Z axis setup on new machine
- stratcat
06 Jun 2016 15:26 #75559
by stratcat
Need help with Z axis setup on new machine was created by stratcat
I would like to set up my machine so that Z Home is around 2 inches and cutting is done at around 0.05 inches
but would like Axis to read "0" at home and all cutting depths to be positive numbers.
In other words, the 0.05" mentioned above would actually be 1.95" in G-Code.
Reason: I'll be using router bits/cutters with different lengths and will use touch-off to derive the actual cutting depth.
I've tried using negative values in "RoboRouter.ini" and can't get Axis to "look" right.
We had a machine using EMC several years ago and I managed to get this to work but forgot what I did.
Thanks for your help.
- BigJohnT
- Thank you received: 994
06 Jun 2016 17:57 #75569
by BigJohnT
Replied by BigJohnT on topic Need help with Z axis setup on new machine
Normally Z0 is at the top of travel for the spindle. You touch off the tool to the work and set the offset to Z0.
JT
JT
Time to create page: 0.124 seconds
