Touch off not zero?
07 Jun 2016 09:15 #75613 by jeeybee
Touch off not zero? was created by jeeybee
Hello
For some reason when I touch off the axis on a lathe I cant set it to zero, when I set it to zero it will be 0.12 for example??
The setup is Mesa 7i77 with analog servo control and the encoders have 2000ppr
07 Jun 2016 11:12 #75624 by andypugh
Replied by andypugh on topic Touch off not zero?
Are you touching-off the tool or the coordinate system?
If you are touching off a tool then you typically need to issue a G43 command too. (I think that Axis might do this automatically, but Touchy doesn't seem to)
07 Jun 2016 11:22 #75626 by BigJohnT
07 Jun 2016 11:36 #75630 by cncbasher
Replied by cncbasher on topic Touch off not zero?
this can also be caused by incorrect entrys in the tooltable
also you may find you need to correctly set the index point of the encoders to the same as home , the small amnount you show
this is probably the main problem , easy way is to home , and then slacken off the encoder mount screws and slowly rotate the encoder to get zero , so zero of the encoder matches your zero point , you could also set an offset value in your ini .
although i personaly prefer to adjust the hardware .
but make sure you dont have any values from tooltables or values in your config first
07 Jun 2016 17:17 #75648 by jeeybee
Replied by jeeybee on topic Touch off not zero?
Thanks for the answers, I will try your suggestions and get back to you.
(its touch off for the coordinate system)
17 Jun 2016 08:21 - 17 Jun 2016 08:22 #76199 by jeeybee
The simple solution was to set HOME = value opposite the error ie if error is 0.2 set to -0.2 (in the INI file)
Last edit: 17 Jun 2016 08:22 by jeeybee.
Time to create page: 0.184 seconds
