Carousel does not home
15 Jun 2016 20:33 #76121 by terkaa
Replied by terkaa on topic Carousel does not home
Ok, I have started writing custom HAL component ARMATC. That will be main component commanding also carousel component. Lets see how it turns out :)
Tero
21 Jun 2016 14:49 - 21 Jun 2016 14:50 #76347 by terkaa
I am seeing now that after homing current-position is 0. Why is this? It should be 1.
Tero
Last edit: 21 Jun 2016 14:50 by terkaa.
21 Jun 2016 17:21 - 21 Jun 2016 17:21 #76360 by andypugh
Replied by andypugh on topic Carousel does not home
That definitely looks like a bug :-(
github.com/LinuxCNC/linuxcnc/blob/master...s/carousel.comp#L246
It sets P to 1, but the next time through P is set to current_position before cirrent_position is set to P.
There needs to be an extra line inserted:
    case 11: // waiting for index & pulse
        if  ( (! old_index) && (sense(0) && sense(1)) ){ // index found
            p = 1;
            current_position = 1;
            homed = 1;
            homing = 0;
            active = 0;
            state = 0;
        old_index = (sense(0) && sense(1));
        break; // So that we don't see the tool1 pulse twice
Last edit: 21 Jun 2016 17:21 by andypugh.
The following user(s) said Thank You: terkaa
21 Jun 2016 17:38 #76361 by terkaa
Ok,
Thanks for checking this. I also noted that when I command jog fwd/rev from my armatc component instead of carousel.ready I had to use !carousel.active because jogging does not need enable it also does not give ready flag. ATC is now working to about middle point of toolchange. I have to implement a spindle orient component tomorrow to go forward with tool change. Component that is readily made does not fit because this spindle does not have feedback from main shaft, only from motor and there is a gearbox between. Also it has mechanical pin that goes into hole to keep spindle still while changing tool. Lets see if I can make it happen....
Tero
22 Jun 2016 07:58 #76399 by terkaa
Time to create page: 0.191 seconds
