Mesa 5i25 skipping commands
12 Jun 2016 02:08 #75841 by eweb101
Mesa 5i25 skipping commands was created by eweb101
Hi all,
I'm pretty new to linuxcnc and am hoping someone can point me in the right direction.
I have linuxcnc set up with a 5i25 card going to a G540 unit then going to my taig mill.
I've made a few parts with it, but today I made my first part that requires a few hours machining time. After about 20 minutes(it varies), the stepper motors stop working for a second or so. It looks like one command is skipped. When they start working again, the coordinates are off and the part gets ruined. A couple times I saw it happen. The servos just stopped, they didn't struggle or anything so it doesn't seem like anything is binding up. I did take the servos off to check everything out and they looked okay.
Any ideas on where to start looking for the problem?
12 Jun 2016 10:20 #75849 by andypugh
Replied by andypugh on topic Mesa 5i25 skipping commands
I wonder if the stepper drives are being disabled somehow?
This is the first time I have ever heard anyone report LinuxCNC to skip a line of code, so I am pretty sure it isn't something that is going on in the actual software. So that leaves the configuration, the drive enable system, the drives themselves or the power supply.
Is it always the same axis that stops, or was it during a move with both axes active?
12 Jun 2016 12:47 #75850 by eweb101
Replied by eweb101 on topic Mesa 5i25 skipping commands
The last three times I tried it, I moved the tool to part 0 on all three axes and the x axis was the only one that was wrong. I guess I could try swapping the x driver on the G540 with the unused driver and see if that fixes the problem. There must be a way to do that.
I was also thinking about buying a cheap parallel port card to see if the 5i25 is the problem.
12 Jun 2016 13:00 #75851 by PCW
Replied by PCW on topic Mesa 5i25 skipping commands
What are you step timings?
The Gecko specified timings will not work with the 3.3V signals the 5I25 outputs
AFAICR you need at least 2.5 usec (2500 ns) for step time
The following user(s) said Thank You: eweb101
12 Jun 2016 13:19 #75852 by eweb101
Would I find the step time setting in the 5i25 firmware somehow, or is it a linuxcnc setting?
12 Jun 2016 13:24 - 12 Jun 2016 13:24 #75853 by PCW
its set in the hal or possibly ini file
Last edit: 12 Jun 2016 13:24 by PCW.
12 Jun 2016 14:19 #75857 by eweb101
I found a parameter called steplen in the hal file that is set to 1000 on each of the three axes. I'll try setting that to 2500 to see if that helps.
13 Jun 2016 10:21 #75906 by andypugh
Yes, that's the one.
13 Jun 2016 12:21 #75912 by eweb101
And that worked! Thanks for the help.
Time to create page: 2.788 seconds
