CNC lost coordinate Z
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Jun 2016 06:13 #75958 by aleksamc
CNC lost coordinate Z was created by aleksamc
HI all.
I have used my cnc successfully for a little time when I used hand milling tool. After that it was broken I have bought 1,5kW spindle with electric drive.
When I've started to work I've seen towards clean work (0,2 mm step on Y) that axis Z lost it's coordinate in the side out from bar)
Every 20-30 mm on Y it lost 1,5-2mm on Z.
Axis Z is horizontal. I use 2,4A stepper motors.
I have checked period jitter, it's OK. More over I have increased it much but still problem enables.
When I test axis Z in stepconfig wizard it was complittly OK with turned on electric drive (invertor).
I suspect greater weight of spindle 2,4kg. I also suspect some nuances in the main program (graphical interface) as sets of Jog.
Can anybody help me?
14 Jun 2016 09:42 #75972 by cncbasher
Replied by cncbasher on topic CNC lost coordinate Z
this sounds more like the common ' missed steps ' , chances are either your microstepping too high , or your velocity or accelleration values again are too high .
remember the higher the microstepping the lower the torque
The following user(s) said Thank You: aleksamc
14 Jun 2016 10:04 #75973 by Rick G
Replied by Rick G on topic CNC lost coordinate Z
Does the Z axis lose it's position if you are making an "air" cut?
Do you get the same problem if you take lighter and or slower cuts?
As cncbasher said you might try reducing the acceleration and velocity of the Z axis.
Also double check that your power supply is sufficient to run all axis at once.
Rick G
14 Jun 2016 10:17 #75974 by BigJohnT
Replied by BigJohnT on topic CNC lost coordinate Z
Did you test your stepper timing to make sure you are not loosing steps?
linuxcnc.org/docs/2.7/html/config/steppe...ostics.html#_testing
JT
  • aleksamc
  • Platinum Member
  • Platinum Member
14 Jun 2016 11:01 #75981 by aleksamc
Replied by aleksamc on topic CNC lost coordinate Z
Thak's all. Really I have tried every thing. I reduced acceleretion and velosity to few mm.
But problem was in another - F..king screensaver of linux broke all my work.
I've turned it off and everything worked fine.
Time to create page: 0.191 seconds
