Jerks when starts program
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Jun 2016 07:24 #76775 by aleksamc
Jerks when starts program was created by aleksamc
I have bought "new" computer with pentium 4 inside. When I move axis of machine in manual mode, everything is OK. But when I start any program axis moves with terrible jerks.
Also when I start emc i see messege "RTAPI: ERROR: Unexpected realtime delay on task 1"
and also look dsmeg.
I had run latency test for an hour, it was written 41500, I wrote 43000.
Where to look this "dsmeg"?
And what it could be with computer? I changed computer to elder and everything works fine.
29 Jun 2016 10:18 - 29 Jun 2016 10:23 #76778 by Rick G
Replied by Rick G on topic Jerks when starts program
Open terminal emulator
type
dmesg
Have you looked here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?TroubleShooting
and
forum.linuxcnc.org/forum/18-computer/190...-the-latency-problem
When running the latency test be sure to put some load on the machine such as running glxgears.
Rick G
Last edit: 29 Jun 2016 10:23 by Rick G.
The following user(s) said Thank You: aleksamc
  • aleksamc
  • Platinum Member
  • Platinum Member
29 Jun 2016 14:10 #76789 by aleksamc
Replied by aleksamc on topic Jerks when starts program
I've found what problem is. Problem was in processor thermal paste of CPU was old and it heats to 98degr!
Now everything is OK.
About links thanks, they helped me much.
