Mesa thcad and mesa 7i76 physical connections
- echesortux
04 Jul 2016 16:46 #76973
by echesortux
Mesa thcad and mesa 7i76 physical connections was created by echesortux
Hello I have a mesa 5i25 with mesa 7i76 doughter card and I am thinking of buying a mesa thcad for torch height control. I have read some post and manual but i can't realize how to wiring plasma cutter + thcad + 7i76.
what i don't realize is how to connect thcad out to encoder input.
FOUT-
FOUT+
FREF+
FREF-
I have attached a picture how I think to connect. plese let me know if I am wrong.
Thanks in advance.
FOUT-
FOUT+
FREF+
FREF-
Thanks in advance.
- Thank you received: 5308
04 Jul 2016 17:31 - 04 Jul 2016 18:13 #76979
Replied by PCW on topic Mesa thcad and mesa 7i76 physical connections
FOUT+ to ENCA+
FOUT- to ENCA-
5V to 5V GND to GND
SHIELD to FRAME GND
FOUT- to ENCA-
5V to 5V GND to GND
SHIELD to FRAME GND
Last edit: 04 Jul 2016 18:13 by PCW. Reason: wrong connections
- echesortux
04 Jul 2016 17:52 #76981
by echesortux
Replied by echesortux on topic Mesa thcad and mesa 7i76 physical connections
what about FOUT+ and FOUT - ?. should I have to left them unconnected?
04 Jul 2016 18:11 #76984
Yep, not used
04 Jul 2016 18:12 #76985
Oops ,sorry go that backwards
FREF+ and FREF - are not used FOUT+ and FOUT-
The following user(s) said Thank You: echesortux
- echesortux
04 Jul 2016 19:26 #76988
by echesortux
Ok I understand. thank you.
last question what mode should I use?
Encoder input mode: differential on single ended mode?
thanks.
thanks.
04 Jul 2016 20:23 #76989
better to use differential mode
- rajsekhar
- Thank you received: 12
07 Aug 2022 05:42 #249251
by rajsekhar
Replied by rajsekhar on topic Mesa thcad and mesa 7i76 physical connections
I need some clarification..
- The input voltage to Mesa THCAD-10 should be less than 10V, am I right??
- The input to be taken across torch clamps?? I am going to use the attached machine.
- In that case, what is the voltage expected there (I do not have any experience till date)??
- And how to calculate the resistor both ohm and wattage??
- Thank you received: 4138
07 Aug 2022 05:51 #249252
Replied by rodw on topic Mesa thcad and mesa 7i76 physical connections
Esab/Thermal Dynamics should be able to supply an automation Interface.
ref: www.ebay.com.au/itm/141477404121
set it to 30:1 divider. Set Linuxcnc/mesa up for a 300v full scale, Then you won't need any scaling resistors.
Note Esab now owns Thermal Dynamics the original manufacturer of your machine.
- rajsekhar
07 Aug 2022 16:09 #249283
by rajsekhar
Dear PCW,
I understand your point and I will ask ESAB for sure.
But can you please answer for THCAD-10 ( I have already in stock, and THCAD 300 is not with me) and if ESAB fail to provide.
Time to create page: 0.153 seconds
