About shared homing
  • marq_torque
  • marq_torque's Avatar Topic Author
  • Elite Member
  • Elite Member
05 Jul 2016 22:12 #77052 by marq_torque
About shared homing was created by marq_torque
Hello all members,
Here i have came across one situation. So thought of new possibility. Thing is i had setup 4 axis machine with shared proxy switches. Now problem i am seeing is if any of home switch is active its not allowing to home as i have set "Home_is_shared = 1" so its working properly. Now question is , is it possible to put some code or value in ini file so that all of axis moves oppositie to home direction till that triggered switch opens ?? And continue homing sequence ??
Ankit
06 Jul 2016 13:13 #77079 by Todd Zuercher
Replied by Todd Zuercher on topic About shared homing
I do not know if that is possible. Good question. But my gut feeling is that the answer is no. (at least not at the moment)
This might be a good feature request.
The following user(s) said Thank You: marq_torque
Time to create page: 0.278 seconds
