minimum feed rate?
10 Jul 2016 00:32 #77238 by clayton cramer
minimum feed rate? was created by clayton cramer
I am trying to set a milling operation at a very low feed rate .000001 ipm. G00 x1 y0 f.000001 I can't see that LinuxCNC actually drops the feed rate to this barely perceptible rate. It won't seem to go below 1 ipm.
10 Jul 2016 00:53 - 10 Jul 2016 00:54 #77239 by PCW
Replied by PCW on topic minimum feed rate?
Feed rate does not apply to rapid moves (G0)
Also note that it will take a long time ( about an hour) for the DRO that reads in .0001" increments
to change at 0.000001 IPM
(hint: watch motion.distance-to-go )
Last edit: 10 Jul 2016 00:54 by PCW.
10 Jul 2016 03:58 #77244 by clayton cramer
Replied by clayton cramer on topic minimum feed rate?
Thanks for your help. I will eventually work my way up to village idiot.
Time to create page: 0.290 seconds
