Edit file
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
17 Jul 2016 06:25 #77563 by Diederik
Edit file was created by Diederik
I have noticed that when I try to edit a file after loading it, that I cannot do it as I used to.
I upgraded to wheezy, and running on 2.7.5, and I used to go to tab-file, then edit. Then my program would open, I could edit it, and reload.
Now I have to find the file in nc-files directory, to edit.
Thanks.
17 Jul 2016 10:07 - 17 Jul 2016 11:14 #77570 by Rick G
Replied by Rick G on topic Edit file
In your config file you select the editor you wish to use. You can change it to mousepad which is probably installed or install gedit.
If you want to use gedit from a termianl try...
sudo apt-get update
sudo apt-get install gedit
To use mousepad edit your ini file from
EDITOR                  = gedit
to
EDITOR                  = mousepad
Rick G
Last edit: 17 Jul 2016 11:14 by Rick G.
The following user(s) said Thank You: Diederik
17 Jul 2016 21:49 #77581 by BigJohnT
Replied by BigJohnT on topic Edit file
If your using Debian and miss the Gedit editor it is simple to get it back. Open a terminal and do the following.
sudo apt-get update
sudo apt-get install -y gedit
sudo apt-get install -y gedit-plugins
JT
  • Diederik
  • Premium Member
  • Premium Member
18 Jul 2016 20:10 #77614 by Diederik
Replied by Diederik on topic Edit file
Yep. That did the trick. Thanks a lot
Time to create page: 0.099 seconds
