Confirmation on charge pump documentation
- GaryLa
19 Jul 2016 13:24 - 19 Jul 2016 13:26 #77639
by GaryLa
Confirmation on charge pump documentation was created by GaryLa
The documentation on this page:
5. Parallel Port Setup
Has a curious statement:
"The charge pump output will be about 1/2 of the maximum step rate shown on the Basic Machine Configuration page."
Why does it read "about", does this mean "approximately"? I assumed the charge pump bit would be coincident with the rest of the changing bits on the LPT. I understand it changing at a lower rate, such as half, but how does the word "about" play into this?
This documentation doesn't say anything specific: Charge Pump Docs
Last edit: 19 Jul 2016 13:26 by GaryLa. Reason: clarity
- Thank you received: 1472
19 Jul 2016 13:39 #77642
Replied by Todd Zuercher on topic Confirmation on charge pump documentation
I am guessing the "about" refers to it being the thread frequency +/- what ever jitter the PC has for that thread.
- GaryLa
19 Jul 2016 13:51 - 19 Jul 2016 13:52 #77644
by GaryLa
Replied by GaryLa on topic Confirmation on charge pump documentation
It seems that all the signals would have to "jitter" together. All bits of the port, I assume, are written on an IRQ at the same time.
It's the frequency that's concerning me. I read the "about" as suggesting the frequency of the charge pump would not necessarily be related to the step/dir pulses.
Last edit: 19 Jul 2016 13:52 by GaryLa. Reason: typo
19 Jul 2016 15:37 #77655
What concerns you about the frequency? To fast or slow, there are multipiers you can use, or run it in a different thread or the servo thread.
- GaryLa
19 Jul 2016 15:52 #77657
by GaryLa
I just imagined the charge pump pin would have to rise with the step and dir (and all the others) and as a result, be related to the step frequency. I am building a PCB for a custom machine and want to use LinuxCNC to drive it.
It would be useful for me to be able to treat the charge pump as a type of clock. If I can't, then I could simply have an "unused-on-my-machine" axis continuously "stepping" to provide a clock.
I'd be fine with the charge pump at any frequency, really, just as long as it was related to the step frequency. Obviously the parallel port pins can be written at any time and certainly a control pin is no exception. I assumed LinuxCNC would write ALL port pins at the same time. This guarantees they are locked together, time-wise. However, if the charge pump pin is written independently of the step bits it wouldn't be locked to the step bits. The word "about" made me curious.
Since the HAL is used to drive the port, I think it's safe to assume the charge pump will be in-sync. But I am going through the source code now to try to confirm that. I'll probably have a couple of birthdays before I get through all of it...
- Thank you received: 5321
19 Jul 2016 16:49 #77658
Replied by PCW on topic Confirmation on charge pump documentation
The chargepump output toggles every base thread invocation
If you want a known fixed frequency clock, you are probably better off using a free stepgen or the siggen component
since you can set the frequency independent of the host base thread setting (which should be set as high as possible for best step generation fidelity) This would make your hardware more portable between systems
Also the stepgen or siggen allow you to set lower frequencies so can have reasonable phase jitter
(the chargepump does have 1/2 and 1/4 frequency outputs but that's it)
The following user(s) said Thank You: GaryLa
- Thank you received: 4652
20 Jul 2016 09:22 #77688
You are right that the pins all change in synch (it's a simple outb call to the parport address) . But the step-gen pins only change every N thread invocations, depending on step rate. The charge-pump changes every thread invocation.
Replied by andypugh on topic Confirmation on charge pump documentation
Time to create page: 0.107 seconds
