workpiece touchoff getting lost (v2.6.4)
- bschiett
21 Jul 2016 14:08 #77775
by bschiett
workpiece touchoff getting lost (v2.6.4) was created by bschiett
Hi All
I'm running linuxcnc 2.6.4 on a cnc router i recently built. It's a manual toolchange machine. I have no tool holders and I touch off to a workpiece, the table or a fixture generally.
I am using fusion 360 to do the cam programming for the router. I have been noticing that depending on the order in which i load my program in linuxcnc and touch off, that it will ignore the touch off i did when i run the program - for example, suddenly there is a 2mm offset in the z axis.
What i normally do is have different operations in different g code files (one per tool since i have to manually change tools and touch off) - so i load a g code file, touch off xyz, then press run, it asks for the tool and i press continue since the tool is already loaded and then when done, i might load another file, same tool or not, touch off if necessary and run, and press continue, etc.
In my tool table i have nothing filled in for x/y/z since i don't have a tool offset (i'm touching off to the workpiece, fixture or whatever). I only have the diameters of the tools in the tool table.
Here is an example of a program where i noticed the x/y touch off shifted by 2mm so it doesn't seem to be an issue only related to z touch off - pastebin.com/Ep0gJMXJ
I've been starting and stopping my program shortly after i hit continue on the dialog popup asking for the tool, to verify and confirm the touch off is still correct. However, this is very time consuming and annoying. I just want to touch off once and then keep loading and running programs and I want the tool touch offs to stay in effect until i put in a new tool and touch off.
I originally downloaded linuxcnc image and put it on a flash drive, i've been running that and haven't installed any upgrades.
@gregcnc on #linuxcnc already mentioned this behaviour might be due to having stopped programs halfway, and that a touch off would be required if that happened, and that this would have been eliminated in 2.7. But he said he isn't 100% sure. Can anyone confirm or does anyone have any other ideas where this is coming from?
Thanks!
B
Thanks!
B
- Thank you received: 4652
21 Jul 2016 14:15 #77776
Replied by andypugh on topic workpiece touchoff getting lost (v2.6.4)
Are you running from the actual flash drive?
Are you 100% certain that there are no offsets in the tool table?
Can you describe the exact sequence you use for touching-off?
- bschiett
21 Jul 2016 14:25 #77777
by bschiett
1) yes, I am running from the flash drive directly, the PC has no hard drive. I could use an SSD and move to that if necessary.
2) when i open the tool table in axis (edit tool table) and look at it there the data fields for the tools are empty, nothing is filled in. do you recommend putting 0 in every field instead? I didn't actually go on the command line and open the file to inspect it.
3) here it is:
I) start axis and home machine
II) load g code file, jog spindle to where i can reach it, put in new tool
III) touch off to fixture (x or y first, then z)
IV) start machine, popup asks for tool, i click continue
V) mill, and stop machine halfway if i'm using only one of two pockets in the fixture
VI) load new g code program for other tool
VII) jog spindle and load new tool
VIII) touch of Z again to fixture
VIV) go to IV)
this is how i mostly do it, sometimes i might have loaded the tool first, touched off Z and then loaded the program, started and clicked continue on the popup. it should not make a difference?
Replied by bschiett on topic workpiece touchoff getting lost (v2.6.4)
3) here it is:
VIV) go to IV)
21 Jul 2016 14:33 #77778
Does Linux have write-access to the USB drive? And are you running a config specific to your machine?
I am surprised that there isn't a problem at step IV if the tool-table is blank and the G-code asks for Tool 1.
The fact that it doesn't complain makes me wonder if there is another tool-table somewhere that is being used.
If the CAM-created G-code is asking for a tool-change then it can save a lot of confusion if you make sure that you do your touch-off with the tool pre-loaded. (M6 T1 G43). ie, at Point 11a, tellthe system that you have loaded a tool.
- bschiett
21 Jul 2016 14:37 #77779
by bschiett
I created a config for my machine using stepconf and then edited the config further to add a probe panel for the touch probe i recently bought from tormach. I've been putting g code in my home dir on this flash drive without a problem so permissions should be no problem? if you tell me what to check specifically i can do that.
the tool table is not blank, i've filled in all the tools but there are no offsets for any of the axis since i don't need any. i just put in new tools as I go, and all i do is enter the diameter of the tool and a comment. if i get an error that a tool doesn't exist i will add the tool and then reload my g code.
I always load my tool manually and touch off before i start my program. so when i get the dialog popup asking to load a tool, i just click continue since I've already loaded the tool at that point.
21 Jul 2016 14:40 #77780
And that _should_ be OK, except that the CAM system is inserting toolchanges and G43 commands.
Even then, it _should_ be OK if the offsets in the tool table are all zero. But the spurious G43 and M6 commands do create scope for trouble.
- bschiett
21 Jul 2016 14:42 #77781
by bschiett
are you saying it would be a better idea to config the post processor / cam software such that it doesn't output these commands?
21 Jul 2016 14:52 #77782
In your situation, I think that would be best, yes.
- bschiett
21 Jul 2016 14:54 #77783
by bschiett
thanks, do you know if this is a bug with 2.6 and if upgrading to 2.7 would fix it?
any other g codes in the beginning of my program which should be removed?
21 Jul 2016 14:58 #77784
I don't think this is a bug, as such. More a wrong-assumption by the default F360 Post-processor.
On my machines (with repeatable tool holders, BT30) the code is correct and it works properly too.
Time to create page: 0.130 seconds
