realtime independent motor control with linuxcnc
- Thank you received: 7493
24 Aug 2016 13:18 #79354
NEVER cut the power to motors by disconnecting motor wires while the drive is powered, that WILL destroy the drive in most cases.
The rest is OK.
Replied by tommylight on topic realtime independent motor control with linuxcnc
If you put a switch on the Z axis enable you can easily run the program as written with the Z axis safely out of the was. If your drive doesn't have an enable feature you can try switching off power to the dive or switching off one wire to each coil going to the Z axis motor.
The rest is OK.
- Badger
- Thank you received: 21
24 Aug 2016 17:10 #79363
by Badger
Replied by Badger on topic realtime independent motor control with linuxcnc
Tommylight -
Thanks for pointing out not to disconnect the motor in any way when the drive is energized. It occurred to me later but I forgot to correct the post. We want to keep all of the magic smoke inside the drive and not let it out.
24 Aug 2016 20:55 #79377
You are welcomed, always.
- giantstone
30 Aug 2016 14:50 #79722
by giantstone
Replied by giantstone on topic realtime independent motor control with linuxcnc
Hi, Badger, I successfully produced dxf files for Gcodetools to create G-codes, thanks so much!
- giantstone
30 Aug 2016 14:54 #79723
by giantstone
out of curiosity, what does regex("G01 A","G00 A") exactly mean?
I tried to google it but I didn't find detailed information, I know A means A axis, G0 is rapid mode, G1 is linear move,
may be the code means to make A axis's feed rate the same as G0 and G1?
- Badger
30 Aug 2016 20:30 #79750
by Badger
This one is a bit odd. In my case I use the A axis to rotate my tool, the rugbot, to keep it tangent to the direction of travel. I don't think you can set a maximum feed rate for the A axis separately from the other axis. So my feed rate is 960 millimeters per minute, and LCNC seems to handle rotation in degrees per minute, so that means that my A axis can only turn at 2.6 RPM. When it is actually moving along a segment it seems to ignore this fact and the A axis rotation will track the XY movement even in a wicked fast tight spiral, which is great. But at some points in the gcode generated by gcodetools I have A axis only moves such as turning a corner between straight lines, in which case LCNC uses the 960 degrees per minute rate associated with a G1 move. This is very slow and annoying. What regex("G01 A","G00 A") does is that when gcodetools is actually writing the gcode, it looks for all of those individual slow G01 moves and rewrites them as G00 moves where I have the maximum velocity for the A axis set for wicked fast. This greatly speeds up the process and makes me less cranky, sometimes.
30 Aug 2016 20:42 #79752
Replied by andypugh on topic realtime independent motor control with linuxcnc
The interesting thing to google there is actually "regex". Fascinating and powerful. And baffling at times.
The filter that changes 2.7 configs to 2.8 is all done with regex.
LinuxCNC should use degrees per min for rotary-only moves. You do need a new F-command.
