Adding HAL components to Glade 3.20
- bodhi_94
29 Jul 2016 14:20 #78139
by bodhi_94
Adding HAL components to Glade 3.20 was created by bodhi_94
I was using glade 3.8.5.. I wish to move glade 3.20 which is supported gtk+3.. After i installed it ,there was no tab called HAL Python and HAL components.. But when i was using 3.8.5 version those were there by default.. Any one could help me to solve this matter?
- Thank you received: 2175
29 Jul 2016 14:46 #78141
Replied by cmorley on topic Adding HAL components to Glade 3.20
gladevcp widgets will not work with GTK3.
The glade editor for GTK3 will not work for gladevcp either (because gladevcp uses GTK2).
You are stuck with glade 3.8.5
Chris M
Chris M
The following user(s) said Thank You: bodhi_94
Time to create page: 0.065 seconds
