after selecting settings ok axis and give it close
31 Jul 2016 21:49 #78210 by l337
I have GNU-Linux ARCH, have compiled LinuxCNC from the AUR repository on my blog as I have put to compile, compile it after the terminal opened and wrote "LinuxCNC" and appeared the next screen
out of terminal
[root@ronal ronal]# linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/usr/share/doc/linuxcnc/examples/sample-configs/sim/axis'
Machine configuration file is 'axis_9axis.ini'
can't find package Linuxcnc
while executing
"package require Linuxcnc "
(file "/usr/share/linuxcnc/hallib/check_config.tcl" line 83)
check_config validation failed
LinuxCNC terminated with an error. You can find more information in the log:
/root/linuxcnc_debug.txt
and
/root/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
31 Jul 2016 22:09 - 31 Jul 2016 22:11 #78212 by BigJohnT
As your venturing into the land of unknown can you post the output from dmesg?
If this is a RIP (Run In Place) did you do after make sudo make setuid then cd .. then . ./scripts/rip-environment?
JT
Last edit: 31 Jul 2016 22:11 by BigJohnT.
01 Aug 2016 02:57 #78219 by l337
this output for dmesg
www.heypasteit.com/clip/2TPP
i dont understand when did you say
"If this is a RIP (Run In Place) did you do after make sudo make setuid then cd .. then . ./scripts/rip-environment?"
[root@ronal ronal]# make setuid
make: *** No hay ninguna regla para construir el objetivo 'setuid'. Alto.
01 Aug 2016 13:28 #78233 by BigJohnT
A RIP is when you download the source and build the software in place (not installed). Looks like your running the computer as root... The dmesg said you ran out of memory for some reason.
What is in
and
Also before running LinuxCNC clear dmesg with dmesg -c or for normal users sudo dmesg -c
JT
01 Aug 2016 21:53 #78258 by l337
hello this sudo dmesg -c
www.heypasteit.com/clip/2TSF www.heypasteit.com/clip/2TSF
linuxcnc_debug.txt --> nothing
linuxcnc_print.txt --> www.heypasteit.com/clip/2TSF
02 Aug 2016 22:48 #78306 by BigJohnT
To my pea brain it looks like a kernel problem, is there some reason your not using a supported distro like Debian?
JT
03 Aug 2016 03:11 #78315 by l337
I will return to reinstall ARCH and be back one Install , I do not like debian
Time to create page: 0.123 seconds
