andypugh wrote: As a data-point I have a lightweight Chinese 9x20 lathe runing with NEMA23 steppers. It has 3.5Nm on Z and a 20mm ballscrew and , 2.5Nm on X with an 8mm ballscrew.
The X is slightly more acceptable than the Z, though parting is a bit of an exercise in frustration. Toolpost drilling is not really an option with anything bigger than 6mm.
It's a perfectly usable lathe, and has made some decent parts but on the basis of that machine my latest conversion (a Holbrook Minor 10 x 20) has 1kW servos on both axes.
For a stepper machine I think I would be looking at 3.5Nm NEMA 23 on X and 5+ Nm NEMA34 on Z.
If you mean the ones with integrated encoders, then that is what I would use if I was building a stepper system.Robotwizard wrote: What are your opinions on hybrid steppers?
