Linuxcncrsh problem
28 Aug 2016 18:15 #79605 by Jzck
Linuxcncrsh problem was created by Jzck
Linuxcncrsh stop working after a few hundred connection. I tried first from localhost, later a separate machine over ethernet.
With v2.5 ubuntu v2.7 debian just the same situation.
The remote commands are just homing and one movement on one axis.
Any idea?
28 Aug 2016 22:33 #79627 by andypugh
Replied by andypugh on topic Linuxcncrsh problem
Does LinuxCNC stop, or does linuxcncrsh stop connecting?
30 Aug 2016 04:23 #79702 by Jzck
Replied by Jzck on topic Linuxcncrsh problem
GUI is working properly, homing, jogging is ok.
Only the remote function hangs., restarting linuxcnc solve the problem for at about 30 minutes.
30 Aug 2016 05:49 #79703 by andypugh
I suspect that linuxcncrsh has so few users that you may not find any help on the forum.
It is probably best to raise a bug report here:
github.com/LinuxCNC/linuxcnc/issues
The following user(s) said Thank You: Jzck
30 Aug 2016 15:38 #79725 by seb_kuzminsky
Replied by seb_kuzminsky on topic Linuxcncrsh problem
Please post the code that you use to talk to linuxcncrsh.
Time to create page: 0.541 seconds
