Getting Started - no tool
30 Aug 2016 07:51 #79706 by mu34tant
Getting Started - no tool was created by mu34tant
bought a little mill of ebay to do stencils. found a low latency motherboard, set up stepconfig. no home switches right now. LinuxCnc doesn't find tool. Any suggestions?
30 Aug 2016 08:40 #79710 by andypugh
Replied by andypugh on topic Getting Started - no tool
Your G-code is probably referencing a to that is not in the tool table.
30 Aug 2016 10:40 #79713 by tommylight
Replied by tommylight on topic Getting Started - no tool
Can you run the AXIS splash gcode that is on when you start Linuxcnc? If yes, then Andy is right, your gcode is requesting a toll that does not exist in your tool table, but you can add it. Go to File>Edit tool table> add the tool number and other info.
Time to create page: 0.190 seconds
