sudo apt-get update fails
- tome
- Thank you received: 11
31 Aug 2016 19:01 #79795
by tome
sudo apt-get update fails was created by tome
I have an 2.7.X installation that I haven't used in a few months. I powered it up today and tried to run Update Manager (and Synaptic) and neither will run, they pop up an error. When I run 'sudo apt-get update' I get the following error:
Hit http.debian.net wheezy-updates/non-free Translation-en/DiffIndex
Ign linuxcnc.org wheezy/base Translation-en
Reading package lists... Error!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/linuxcnc.org_dists_wheezy_2.7-rtai_i18n_Translation-en
E: The package lists or status file could not be parsed or opened.
I tried deleting the file /var/lib/apt/lists/linuxcnc.org_dists_wheezy_2.7-rtai_i18n_Translation-en (which is present and seems to have proper permissions) but just get:
E: Problem with MergeList /var/lib/apt/lists/linuxcnc.org_dists_wheezy_2.7-rtai_i18n_Translation-en%5fUS
How can I get the system to update?
Thanks,
-Tom
Thanks,
-Tom
- tome
31 Aug 2016 19:10 #79796
by tome
Replied by tome on topic sudo apt-get update fails
Time to create page: 0.079 seconds
