unable to toggle machine power by python interface
- giantstone
01 Sep 2016 02:21 #79807
by giantstone
unable to toggle machine power by python interface was created by giantstone
HI, I'm using python interface trying to automatically run linuxcnc,
when I used
if task_state !=2 :
c.state(linuxcnc.STATE_ON) #
c.wait_complete() # wait until mode switch executed
print 'state changed to', getattr(s, 'task_state' )
the machine's task state made no change. I have to manually click on the toggle machine power.
here is my script:
import linuxcnc
import numpy as np
if __name__ == '__main__':
try:
e = linuxcnc.error_channel()
s = linuxcnc.stat() # create a connection to the status channel
c = linuxcnc.command()
c.reset_interpreter()
c.teleop_enable(1)
task_state = getattr(s, 'task_state' )
task_mode = getattr(s, 'task_mode' )
homed = getattr(s, 'homed' )
current_line = getattr(s, 'motion_line' )
## motion_mode = getattr(s, 'motion_mode' )
motion_type = getattr(s, 'motion_type' )
paused = getattr(s, 'paused' )
print 'task_state',task_state,'task_mode',task_mode, 'homed',homed
print 'current_line',current_line,'paused',paused
if task_state !=2 :
## if np.sum(homed)<4: # X Y Z A
## if task_mode !=1: #(MODE_MDI, MODE_MANUAL, MODE_AUTO).
## c.mode(linuxcnc.MODE_MANUAL ) #linuxcnc.MODE_AUTO
## c.wait_complete() # wait until mode switch executed
## c.home(0)
## c.home(1)
## c.home(2)
## c.home(3)
## print 'homed', getattr(s, 'homed' )
if task_mode !=2: #(MODE_MDI, MODE_MANUAL, MODE_AUTO).
c.mode(linuxcnc.MODE_AUTO) #linuxcnc.MODE_AUTO
print 'mode changed to', getattr(s, 'task_mode' )
print 'working'
c.abort()
c.program_open("/home/sam3/linuxcnc/NGC_file/fur_cut1.ngc")
c.auto(linuxcnc.AUTO_RUN, 0)
flag = 0
while 1:
error = e.poll()
print_error(error)
s.poll() # get current values
## print getattr(s, 'dtg' )
print 'motion_type',motion_type,'task_mode',task_mode
if motion_type == 2 and flag==0 :#0 = idle 1: Traverse 2: Linear feed 3: Arc feed 4: Tool change 5: Probing 6: Rotary axis indexing)
c.auto(linuxcnc.AUTO_PAUSE) #run, step, pause or resume a program
c.auto(linuxcnc.AUTO_RESUME) #run, step, pause or resume a program
flag=1
except linuxcnc.error, detail:
print "error", detail
sys.exit(1)
finally:
c.abort()
I also tried to home axes, but it didn't work neither. ( see the commented section above).
could someone help me to address these issues?
when I used
if task_state !=2 :
here is my script:
import linuxcnc
import numpy as np
try:
c.teleop_enable(1)
if task_state !=2 :
## c.home(0)
## c.home(1)
## c.home(2)
## c.home(3)
print 'working'
c.abort()
flag = 0
while 1:
error = e.poll()
print_error(error)
flag=1
sys.exit(1)
finally:
c.abort()
- Thank you received: 2173
01 Sep 2016 05:30 #79811
Replied by cmorley on topic unable to toggle machine power by python interface
You must poll before checking task state.
I started linuxcnc, then opened a python terminal:
worked fine.
Also would recommend not using code like this:
if task_state !=4 :
instead use:
if task_state !=linuxcnc.STATE_ON:
It's safer, in the future the enumeration may change but the command name should not.
Chris M
>>> import linuxcnc
>>> c.state(linuxcnc.STATE_ESTOP_RESET)
>>> s = linuxcnc.stat()
>>> s.poll()
>>> print task_state
4worked fine.
if task_state !=4 :
instead use:
Chris M
The following user(s) said Thank You: giantstone
- giantstone
01 Sep 2016 06:05 - 03 Sep 2016 11:53 #79813
by giantstone
Replied by giantstone on topic unable to toggle machine power by python interface
Hi, Chris, Thanks for your reply,
I solved the issue now. here is my updated scripts:
import linuxcnc
import numpy as np
try:
c.teleop_enable(1)
if task_state != linuxcnc.STATE_ON :
print 'state changed to', task_state
if np.sum(homed)<4:
if task_mode !=linuxcnc.MODE_MANUAL : #(MODE_MDI, MODE_MANUAL, MODE_AUTO).
c.home(0)
c.home(1)
c.home(2)
c.home(3)
print 'homed', homed
if task_mode !=linuxcnc.MODE_AUTO: #(MODE_MDI, MODE_MANUAL, MODE_AUTO).
print 'mode changed to', task_mode
print 'working'
c.abort()
flag = 0
while 1:
error = e.poll()
print_error(error)
flag=1
sys.exit(1)
finally:
c.abort()
Last edit: 03 Sep 2016 11:53 by BigJohnT. Reason: add code tags
- BigJohnT
- Thank you received: 994
03 Sep 2016 11:56 #79969
by BigJohnT
Replied by BigJohnT on topic unable to toggle machine power by python interface
It's much clearer to read if you just do a straight compare of the status. There is no need to use getattr in this example.
JT
if s.task_state != linuxcnc.STATE_ON:JT
Time to create page: 1.299 seconds
