Loading no g code file on startup
13 Sep 2016 20:01 #80419 by Rick G
Replied by Rick G on topic Loading no g code file on startup
I assume this becomes also the active g code string listed on the mdi screen ?
Yep, when you run the file it will set the active g codes and settings for you.
So you could automatically start with blank screen and the settings you want and or select the same file to reset your machine with a blank screen.
Rick G
Time to create page: 0.542 seconds
