Current Active Codes Update in Auto
- snujcnc
- Thank you received: 4
14 Sep 2016 07:54 #80427
by snujcnc
Current Active Codes Update in Auto was created by snujcnc
Hi..
I am Looking For list of current active g ,m,s,t codes
i can get actual update in mdi mode when i make any change i can see in curren active g codes ,mcodes spindle speeds etc.
but during automatic mode program is running i am not able to see any code updated
for example
in auto mode is there is g90 code in first line and after some movement if g91 code came
no updated value came out in active g code list in auto mode in mdi it is working ok
also if i start repeat code program like bellow
g90
g0x0y0
o12 REPEAT [10]
g91
g0x100
x-100
o12 END REPEAT
g90
g0x0y0
m30
how i can get value of repeat cycle
i want to know currently how many passes finished of which pass is running of REPEAT cycle
1,2,3...etc
if some one guide please help me
for example
g90
g0x0y0
o12 REPEAT [10]
g91
g0x100
x-100
o12 END REPEAT
g90
g0x0y0
m30
1,2,3...etc
- Rick G
- Thank you received: 114
15 Sep 2016 11:17 - 15 Sep 2016 20:53 #80468
by Rick G
Replied by Rick G on topic Current Active Codes Update in Auto
To see the repeat line you can add a debug line to your code.
linuxcnc.org/docs/html/gcode/overview.html#gcode:debug
Perhaps
g90
g0x0y0
#<cycle> = 1
o12 REPEAT [10]
(debug, Cycle #<cycle>)
g91
g0x100
x-100
#<cycle> = [#<cycle> + 1]
o12 END REPEAT
g90
g0x0y0
m30
The active g-code window will not update the way you want while a program is running.
I think of the window when running a program as the state the machine will be in when it completes running the current program.
Rick G
Perhaps
g90
g0x0y0
#<cycle> = 1
o12 REPEAT [10]
g91
g0x100
x-100
o12 END REPEAT
g90
g0x0y0
m30
Active G-Codes - This shows the modal codes that are active in the interpreter. For instance, G54 indicates that the G54 offset is applied to all coordinates that are entered. When in Auto the Active G-Codes represent the codes after any read ahead by the interpreter.
Rick G
Last edit: 15 Sep 2016 20:53 by Rick G.
The following user(s) said Thank You: snujcnc
- Thank you received: 4652
18 Sep 2016 19:50 #80578
Replied by andypugh on topic Current Active Codes Update in Auto
The real-time motion code and the user-interface code run in different spaces, and are not very well informed on the state of the other.
The G-code interpreter feeds the motion into a queue that it consumed by the real-time code. In many cases the queue contains the whole sequence of moves before the tool even touches the workpiece.
This means that the two sections can have very different opinions on the state of the machine. It's odd, but that's the way it is.
Time to create page: 0.071 seconds
