Hostmot2 firmware
- soroosh.av
17 Sep 2016 08:13 #80516
by soroosh.av
Hostmot2 firmware was created by soroosh.av
I want to use messa 7i43-4 board. I tried to download packages using synaptic package manager but faced with an error:
https://package URL
404 not found.
Is there any way to download and install the packages manually? Or fixing that error somehow?
https://package URL
404 not found.
- Thank you received: 7478
17 Sep 2016 12:13 #80521
Replied by tommylight on topic Hostmot2 firmware
mesanet.com/
Go to Anything I/O cards, middle of the page has 7I43 and the documents and software for it.
The following user(s) said Thank You: soroosh.av
- soroosh.av
18 Sep 2016 03:00 - 18 Sep 2016 04:50 #80552
by soroosh.av
Replied by soroosh.av on topic Hostmot2 firmware
But how can use this on Ubuntu?
There are many .BIT files in different folders, I want to use USB input and there are many folders with that name inside the ZIP file.
Which one is right for me?
Last edit: 18 Sep 2016 04:50 by soroosh.av.
18 Sep 2016 11:42 #80556
I am not qualified to answer that, sorry.
- Thank you received: 5326
18 Sep 2016 13:12 #80561
Replied by PCW on topic Hostmot2 firmware
The USB firmware will not work with LinuxCNC (at least for real time motion control.
LinuxCNC only supports EPP mode with the 7I43
The following user(s) said Thank You: tommylight, soroosh.av
- soroosh.av
18 Sep 2016 16:01 #80572
by soroosh.av
Thanks for your help. And one more question is that do I need to configure the related PCI in the hal file?
I used a Linux CNC configuration example for that and there was nothing about PCI configuration inside related hal file.
18 Sep 2016 16:40 - 18 Sep 2016 16:40 #80573
If you are using a 7I43 in EPP mode you will need to know the base
address of the PCI parallel port that's interfaced to the 7I43
You can either rely on Linux's port enumeration and use port addresses 0 or 1 for parallel port numbers
or use lspci to find the base address of the parallel port
Note that many PCI parallel ports are based on the NetMOS/MOSChip 9805 series chips
Unfortunately these chips do not implement EPP mode correctly so cannot be used with the 7I43
As a general rule you are better off using a PC with a built in parallel port when using a 7I43 in EPP mode
Last edit: 18 Sep 2016 16:40 by PCW.
Time to create page: 0.201 seconds
