gantry machine different motor respond
19 Sep 2016 12:44 #80602 by mpvriens
gantry machine different motor respond was created by mpvriens
Have a gantry machine , running on master and gmoccapy , when homing the two gantry axis, in joint mode, i see a time difference in respond of the tho joint commands
I this adjustable?
Marius
19 Sep 2016 17:23 #80622 by Todd Zuercher
Replied by Todd Zuercher on topic gantry machine different motor respond
could you elaborate on your "time difference in respond of the tho joint commands"?
22 Sep 2016 05:57 #80764 by mpvriens
Replied by mpvriens on topic gantry machine different motor respond
when homing in joint mode, i see one the DRO one of the motors running ahead in time (about 0,5 sec) on the other motor,
So the machine has to wait on one of the motors before he switched to world mode,
Also when routing a circle, you can see the circle is not round at the point it changes direction of the X axis (ganrty axe)
have no backlash on the motors
Marius
22 Sep 2016 14:09 #80769 by PCW
Replied by PCW on topic gantry machine different motor respond
is there a difference in commanded position or just feedback position? (the DRO can read either)
if the difference is just in feedback position, this is possibly a tuning issue
Can you post your HAL/INI files here
23 Sep 2016 10:56 #80826 by mpvriens
I expect it to be the feedback position
23 Sep 2016 12:37 #80829 by PCW
I noticed home latch velocity is different between the two slaved axis
so i would check you INI file carefully for other differences
(maybe copy/paste duplicate both slaved axis ini file sections from one source so you are sure they are identical)
The following user(s) said Thank You: mpvriens
