Best PC setup for 2 port parallel step mesa 5i25?
10 years 1 month ago #81083 by Ian@eagland.co.uk
Hi
I have just installed LinuxCNC onto a Taig mill. For historic reasons the interface BOB I built many years ago has twin 25D parallel port connections. I have three old PCs and they all work but I cannot get very good rapid speeds as the PCs are slow. Am I correct in understanding that if I fit a Mesa 5i25 board this overcomes the timing issues? Also it seems that the Mesa 5i25 can be set up with two 25D ports so I could just connect my existing cables. Is this correct?
This seems to me to be the most cost effective solution as the alternative is to build a fast PC and purchase a 2 port parallel card.
I would be grateful for any thoughts/advice or details of other peoples experience.
Regards
Ian
10 years 1 month ago #81088 by Todd Zuercher
10 years 1 month ago #81089 by BigJohnT
I just need to know the pinouts of the BOB's to select the proper bit file.
You will need both of these.
mesaus.com/index.php?route=product/produ...ath=62&product_id=51
mesaus.com/index.php?route=product/produ...ath=71&product_id=70
JT
10 years 1 month ago #81101 by Ian@eagland.co.uk
Many thanks.
Parts on order!
10 years 1 month ago #81121 by BigJohnT
Many Thanks, Parts on the way.
JT
10 years 1 month ago #81122 by BigJohnT
JT
