Accessing HAL pin from gcode
29 Sep 2016 18:29 #81084 by wn007
Accessing HAL pin from gcode was created by wn007
I have features = 12 enabled and the gcode loads ok however the resultant #1 = #[<_hal.mycomp.xoffset>] always evaluates to 0.000 even though the HAL component shows a non-zero value. I have seen where the hal pin needs to have a -f appended is this the case?
30 Sep 2016 04:01 #81099 by Larry
Replied by Larry on topic Accessing HAL pin from gcode
Hi wn007:
Based on your description, there really isn't a lot to go on. However if you check out the, “M codes”, particularly M62 – M68, that might be a nice place to start.
30 Sep 2016 05:04 #81100 by Rick G
30 Sep 2016 12:41 #81103 by wn007
Replied by wn007 on topic Accessing HAL pin from gcode
Yes, I have gone through that topic several times.
I am on 2.7.4
Here is the gcode that I am using. The strange thing is that when I load the ngc file from disk it actually executes the while loop within the oword subroutine immediately (while parsing). It appears to only update the HAL pin on the program load not while executing the gcode.
G20
G91
G94
G1 Z89.053 F10
G1 B8.0168 X9.03586959 F250
G1 W1.07238080 F15
G1 Y10.3500000000 F325
M64 P3
M65 P3
#1 = #<_hal[motion.analog-in-00]>
o<take_pics> call [#1]
M30
o<take_pics> sub
G91
#2 = .485
o100 do
#3 = #2 - #1
#4 = #3 / 8
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
M62 P3
G1 Y-.05 X#4 F50
M63 P3
o100 while [#1 NE 0]
30 Sep 2016 13:48 #81105 by Todd Zuercher
Replied by Todd Zuercher on topic Accessing HAL pin from gcode
What if you tried this.
G20
G91
G94
G1 Z89.053 F10
G1 W1.07238080 F15
M64 P3
M65 P3
M66 E0
#1 = [#5399]
M30
o<take_pics> sub
G91
#2 = .485
o100 do
#3 = #2 - #1
#4 = #3 / 8
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
G1 Y-.05 X#4 F50
M62 P3
G1 Y-.05 X#4 F50
M63 P3
M66 E0
#1 = [#5399]
30 Sep 2016 13:55 #81107 by wn007
I have tried the M66 E0 which in fact works, however it breaks blending so there is a pause between successive loops. We are attempting to eventually reach 300 to 400 IPM with no pauses / breaks in the execution. Thanks for the reply.
30 Sep 2016 14:11 - 30 Sep 2016 14:13 #81110 by Todd Zuercher
I'm not sure it can be done without breaking blending, because blending can't be calculated if the move is unknown.
Last edit: 30 Sep 2016 14:13 by Todd Zuercher.
02 Oct 2016 16:48 #81152 by andypugh
Replied by andypugh on topic Accessing HAL pin from gcode
Yes, this is the problem with G-code access to HAL pins. The values get read-in while the motion queue is being filled, not at the point that the G-code line is executed. (I thought that the docs mentioned that)
03 Oct 2016 00:51 #81162 by Todd Zuercher
You might be able to achieve your goal by using a slightly different approach. Could you do your math and check your analog pin in hal, then having hal set a motion.digital-in bit that then breaks your G-code loop? If you need to control the values of your points set them with an analog out, in the code but do the realtime testing in hal.
03 Oct 2016 11:53 #81174 by wn007
Yes, I did find in the docs where the inline HAL is evaluated once on load and should not be used for current values during execution.
Time to create page: 0.124 seconds
