Servo Limit Switch Setup
- register
11 Oct 2016 06:48 - 11 Oct 2016 06:48 #81539
by register
Servo Limit Switch Setup was created by register
I'm building a milling machine using Mitsubishi MR-J2s servos controlled by LinuxCNC.
These servos have an optional (can be turned off in amp parameters) limit switch input that will lock the motor when the input is taken low.
I know that my Mesa 7i76 can also take limit switch inputs, so the question is: which one to implement? It seems to me like it's a better idea to have the control handling the limit switches, but I want to make sure I'm not accidentally overlooking any benefits to having the servo amp interface with the limits directly.
Can anybody with experience chime in?
Thanks!
Henry
Thanks!
Henry
Last edit: 11 Oct 2016 06:48 by register.
- Muzzer
- Thank you received: 42
11 Oct 2016 10:52 - 11 Oct 2016 10:53 #81540
by Muzzer
Replied by Muzzer on topic Servo Limit Switch Setup
I have just acquired a large milling machine with sizable servos, fitted with a home and 2 limit switches on each axis. I'd be interested to hear what the experts have to say but my understanding is that LinuxCNC doesn't require more than the homing switch and can do the rest in software. That's assuming the software and all its external connections are behaving of course.
My thoughts are to use the end of travel limit switches as "dead stop" inputs to the servos, at a similar (higher functional) level as the e-stop circuit. They should never be required but a single failure could be expensive and / or dangerous.
The original servo system has "directional" limit switches that directly inhibit the servos in the direction of travel only, so that you can jog back out. I believe they are implemented independently of the main controller.
Last edit: 11 Oct 2016 10:53 by Muzzer. Reason: Typo
- Thank you received: 4654
11 Oct 2016 12:23 #81542
If LinuxCNC has a home switch to get an absolute position reference from then it should never hit the limit switches.
So, I think it makes more sense to connect the limits to the drive, to catch the situation where LinuxCNC goes wrong.
But, this means that you can't use a limit switch for home, as attempting to do so would cause the drive to stop.
Replied by andypugh on topic Servo Limit Switch Setup
- Thank you received: 1476
11 Oct 2016 12:55 #81544
Replied by Todd Zuercher on topic Servo Limit Switch Setup
Actually I have a machine with a similar servo drive configuration (using parallel port stepping). I have the limit switches connected to both the drive and to Linuxcnc, and I am homing to one of the limits, and it seems to work just fine (at least for this application). The important factor for it to still work is that the drive only inhibits the motion towards the limit, but still lets it jog off. If the drive errors out and shuts down then it would not work.
- Muzzer
11 Oct 2016 13:46 #81546
by Muzzer
That's particularly important if, like mine, there are no handles on the leadscrews.
I hope to retain the directional limit switch operation, independent of the controller.
Time to create page: 0.425 seconds
