G0704 Conversion & Closed Loop Easy Servo's
  • Rhine_Labs
  • Rhine_Labs's Avatar Topic Author
  • Senior Member
  • Senior Member
09 Nov 2016 20:06 - 09 Nov 2016 20:09 #82626 by Rhine_Labs
So i have nearly all the parts to do the conversion... Even some standard steppers? but thinking of the Leadshine Eazy Servos?
Opinions? Any Disadvantages? or Advantages?
The Leadshine models below?
2 X 60HBM30-1000+HBS86H 425oz X-Y
1 X 86HBM80-01-1000+HBS86H 1143oz Z
Should i Splurge on the Driver or use a standard Stepper drive and Tie the Encoders in to a Mesa Board and let LCNC do the math?
Last edit: 09 Nov 2016 20:09 by Rhine_Labs.
09 Nov 2016 21:13 #82629 by Todd Zuercher
Replied by Todd Zuercher on topic G0704 Conversion & Closed Loop Easy Servo's
I would think the closed loop stepper driver is well worth their cost. I have heard they are quite good, but I have no experience with them.
Trying to do meaningful closed loop stepping with ordinary dumb hardware, is not as simple as it might appear on the surface.
10 Nov 2016 09:21 #82642 by rodw
Thes guys have a range of servos that are a drop in replacement for a stepper motor that use your existing step/dir controller
www.teknic.com
Time to create page: 0.066 seconds
